file jQuery Easy and K2 not working
8 years 5 months ago #4758 by shultman
Replied by shultman on topic jQuery Easy and K2 not working
>The same thing happened again, updated Joomla to 3.6.5, K2 to 2.7.1, JA T3v3 2.6.3, Contact Enhanced 3.6.5 and CB 2.1.2.
I have problems with frontend editing in K2, either the modal window does not show or modal window shows but Save and Cancel don´t work, and the site reloads in the modal window.
8 years 5 months ago #4759 by syw
Replied by syw on topic jQuery Easy and K2 not working
Do you see any javascript errors in the browser console? (usually, hit F12 in your browser on a PC to show the developer tools)
If not, I would suggest you contacts the K2 support.
If you do see errors, send me an email with the URL, access credentials, and I will take a look.
8 years 5 months ago - 8 years 5 months ago #4760 by shultman
I get this error:
TypeError: parent.$(...).removeEvents is not a function[Läs mer]  k2.js:587:20
	<anonymous> https://mysite.org/media/k2/assets/js/k2.js:587:20
	n.Callbacks/i https://mysite.org/media/jui/js/jquery.min.js:2:27444
	n.Callbacks/j.fireWith https://mysite.org/media/jui/js/jquery.min.js:2:28213
	.ready https://mysite.org/media/jui/js/jquery.min.js:2:30004
	K
I will try to ask the same question at K2, but the last time this happened, the answer was here. :)
I think JA T3 loads jQuery last.
Last edit: 8 years 5 months ago by shultman. Reason: typo
8 years 5 months ago - 8 years 5 months ago #4761 by syw
Do you have jQuery Easy setup on the page?
If you now see such error after an update, that may just be a bug in K2.
Last edit: 8 years 5 months ago by syw.
8 years 5 months ago #4762 by shultman
syw wrote: Do you see any javascript errors in the browser console? (usually, hit F12 in your browser on a PC to show the developer tools)
Thanks. Where can I find your email? There are errors. And yes, i have jQuery Easy set up.
8 years 5 months ago #4763 by shultman
