file jQuery Easy and K2 not working
9 years 11 months ago #4402 by shultman
jQuery Easy and K2 not working was created by shultman
I have a Joomla 3.4.4 site with K2 2.7.0 and JA Univerity template (and more).
I cannot get K2 frontend editing to work. It looks like jQuery does not load and/or js loads in wrong order.
I have tried lots of settings with and withpout jQuery Easy but I cannot find a setting that works.
Are you aware of any general issues with K2 and jQuery Easy?
Would you have any suggestions how to solve this?
Any help out of this dead end would be much appreciated!
There is a long discussion @K2 forum about this:
www.joomlaworks.net/forum/k2-en/42608-fr...ting-to-3-4-3#146856
9 years 11 months ago #4403 by admin
Replied by admin on topic jQuery Easy and K2 not working
I am not aware of any issue between K2 and jQuery Easy.
Have you tried disabling jQuery from the K2 global configuration (jQuery library handling parameter) ?
You can just have jQuery Easy load jQuery instead.
Note that jQuery Easy won't do any good if the template or any other extension minimizes/bundles scripts.
9 years 11 months ago #4404 by shultman
Replied by shultman on topic jQuery Easy and K2 not working
Thanks for answering so quickly!
Yes, I have tried disabling jQuery within K2 config but it made no difference.
I am afraid my jQuery skills are very limited... :(
So I am unsure about what can cause conflicts and what to look for.
I have more extensions installed, like Community Builder, JEvents, AcyMailing, Contact Enhanced.
Would you mind having a look at the site?
Sune
9 years 11 months ago #4405 by admin
Of course!
I was going to suggest it to you.
Send your credentials to [email protected] and I will take a look.
9 years 11 months ago #4406 by shultman
Will send in a Little while.
I just noticed that I have the same problem with frontend eding in Contact Enhanced; Save and Cancel don´t work.
I am having the same discussion with CE developer now.
Kind regards,
Sune
9 years 11 months ago #4407 by admin
No problem Sune.
