question-circle jQuery Not Defined
10 years 2 months ago #4311 by primus ltg
Replied by primus ltg on topic jQuery Not Defined
Chrome no longer throws an error.
I am having problems with the extension: JoomUtra USAMap
Do you see any issues I should look into?
jQuery Easy Modifications Report
re-ordered header libraries
removed jQuery.noConflict();
removed 1 jquery-noconflict.js script(s)
removed jQuery library /media/jui/js/jquery.min.js
removed jQuery library /templates/lightwork9/jquery.js
added the jQuery library http://ajax.googleapis.com/ajax/libs/jquery/1.8/jquery.min.js
removed 1 Migrate script(s)
added the jQuery Migrate plugin http://ajax.aspnetcdn.com/ajax/jquery.migrate/jquery-migrate-1.2.1.min.js
added the script /plugins/system/jqueryeasy/jquerynoconflict.js
removed 4 empty script tag(s)
Execution time (in seconds): 0.045971155166626
10 years 2 months ago #4312 by admin
Replied by admin on topic jQuery Not Defined
If you still have a blank screen when you enable the extension JoomUtra USAMap, I would suggest contacting the developers and/or use their support (make sure it is compatible with the latest version of Joomla and see if other users have issues with it).
You can also see if you get any error when setting debug 'on' in the joomla global parameters.
