question-circle jQuery Not Defined
10 years 2 months ago #4305 by primus ltg
jQuery Not Defined was created by primus ltg
I am getting this error on every page of the site:
ReferenceError: jQuery is not defined
http://www.primuslighting.com/components/com_k2/js/k2.js?v2/6/7&sitepath=:1
this page who't open at all:
www.primuslighting.com/index.php/reps
This page has a lot of Javascript on it.
Installing jQuery Easy didn't have any effect even after some tweeking
Everything was fine till we upgraded to Joomla 3.4.
10 years 2 months ago #4306 by admin
Replied by admin on topic jQuery Not Defined
you are getting this error because jQuery is loaded after k2.js, therefore the K2 script does not find jQuery.
Even though you think jQuery Easy had no effect, I still believe it would put everything in order and remove the extra libraries that are loaded on the pages.
Could you please enable the error reporting in the jQuery Easy plugin, it will help in understanding what the plugin does on your pages and it will show what are your settings.
You could also make sure that none of your extensions loads jQuery (when possible) and let the jQuery Easy plugin do it instead. That will minimize the conflicts from the start and improve performance. Check in your template and k2 to see if you can avoid the jQuery loading (possible in K2 for sure).
As far as the empty page is concerned, enumerate all extensions that are loaded on the page, disable the ones that are loaded on that page only and see if your page loads again. At this point there is nothing telling that it is a javascript error and not a bug in an extension instead.
10 years 2 months ago #4307 by primus ltg
Replied by primus ltg on topic jQuery Not Defined
I was not able to find a place to turn on error reporting in jQuery Easy, I turned on error reporting Joomla! but did not see anything about jQuery.
I had previously disabled K2 from loading it's jQuery libraries.
I continue to get the same error on the front page.
Following your advise I am looking into the extensions on the page that includes JoomUtra USAMap
10 years 2 months ago - 10 years 2 months ago #4308 by admin
No problem. The reporting tool is found in the jQuery Easy plugin, in the 'other' tab. Set 'show report' to 'yes'. This is the only way to see what the plugin does.
Last edit: 10 years 2 months ago by admin.
10 years 2 months ago #4309 by primus ltg
I turned reporting on and got this:
jQuery Easy Modifications Report
re-ordered header libraries
Execution time (in seconds): 0.00087165832519531
I have already re-ordered jQuery Easy from last to first, to just before K2. to no effect.
10 years 2 months ago #4310 by admin
Perfect, that tells me you are missing something:
there won't be any fixing by the plugin until you enable jQuery and select a jQuery version in the jQuery Easy plugin. You will also need to enable Migrate.
