question-circle Simple Responsive Slideshow not working
10 years 7 months ago #4026 by admin
Replied by admin on topic Simple Responsive Slideshow not working
Once again, the 'gallery phocabar' working is luck. You have tons of errors on your page.
jQuery Easy is having no effect on the pages which makes me think the plugin is now first to make changes, not last (so you have it in the wrong order). It did all changes needed (hence the report), then all got overridden by the other plugins.
The following user(s) said Thank You: bujinkanat
10 years 7 months ago #4027 by bujinkanat
Replied by bujinkanat on topic Simple Responsive Slideshow not working
Now i get this:
jQuery Easy Modifications Report
jQuery is loaded by the template
Bootstrap is loaded by the template
re-ordered header libraries
removed if (jQuery) jQuery.noConflict();
removed jQuery.noConflict();
removed 2 jquery-noconflict.js script(s)
removed jQuery library /media/jui/js/jquery.min.js
removed jQuery library www.bikestore-austria.com/modules/mod_ga...script/jquery.min.js
removed jQuery library /templates/jp_american_motorcycle/superfish/js/jquery.js
added the jQuery library //ajax.googleapis.com/ajax/libs/jquery/1.9.1/jquery.min.js
removed 1 Migrate script(s)
added the script /plugins/system/jqueryeasy/jquerynoconflict.js
removed 6 empty script tag(s)
Execution time (in seconds): 0.11064291000366
Is this a problem of the template?
10 years 7 months ago #4028 by bujinkanat
Thank you, i found another solution.
All the best
Markus
10 years 7 months ago #4029 by admin
No problem Markus.
Just to let you know, although your page works (mostly), you still have multiple errors on the pages (menu code - superfish, social links sidebar code, Joomla tooltips, touch devices code) and several jQuery libraries loaded... You eliminated one problem with the slider (which uses MooTools) but your jQuery issues are not over yet.
