question-circle Simple Responsive Slideshow not working
10 years 7 months ago #4020 by bujinkanat
Simple Responsive Slideshow not working was created by bujinkanat
Hello, i use a Slideshow on www.bikestore-austria.com but the Slideshow dont show of. I have big Problems with jQery Easy Plugin. I dont now how i can resolve this Problem with your Plugin. I tried to understand your manual, but i fail. Please can you help me?
Markus
10 years 7 months ago - 10 years 7 months ago #4021 by admin
Replied by admin on topic Simple Responsive Slideshow not working
Hello Markus,
the issue you are having is that you selected the versions 9 of jQuery and jQuery UI but omitted to specify the sub-versions in the sub-version fields. for jQuery, use '1', for jQuery UI, use '2'.
Last edit: 10 years 7 months ago by admin.
10 years 7 months ago - 10 years 7 months ago #4022 by bujinkanat
Replied by bujinkanat on topic Simple Responsive Slideshow not working
Hello Admin, at first thank you very much for your help. But if i use '1', for jQuery UI, use '2'. Nothing happens.
And now the Modul "gallery phocabar list" on the Site: www.bikestore-austria.com/index.php/bikes.html isn´t working any more!?
Last edit: 10 years 7 months ago by bujinkanat.
10 years 7 months ago #4023 by admin
You are welcome,
I just got my answer wiped out by your last edit :-)
In fact, now you do have jQuery properly set on your site, which was not the case before.
You were just lucky the module 'gallery phocabar list' was working before.
I have several questions:
- are you sure you need jQuery UI? If not, turn it off
- can you turn on error reporting on the jQuery Easy plugin? Thank you.
- can you re-order your system plugins so that jQuery Easy is the last called (make it the last of the list)? It is to make sure jQuery Easy is the last plugin called. There is a version of jQuery that is not removed
- it looks like you have jQuery set to 1.8.1. Use 1.9.1.
We have to go step by step :-)
10 years 7 months ago #4024 by bujinkanat
Hello Olivier, i think i have done all the steps. Now noting is working, but i have the report for you:
jQuery Easy Modifications Report
jQuery is loaded by the template
Bootstrap is loaded by the template
re-ordered header libraries
removed if (jQuery) jQuery.noConflict();
removed jQuery.noConflict();
removed 2 jquery-noconflict.js script(s)
removed jQuery library /media/jui/js/jquery.min.js
removed jQuery library www.bikestore-austria.com/modules/mod_ga...script/jquery.min.js
removed jQuery library /templates/jp_american_motorcycle/superfish/js/jquery.js
added the jQuery library //ajax.googleapis.com/ajax/libs/jquery/1.9.1/jquery.min.js
removed 1 Migrate script(s)
added the script /plugins/system/jqueryeasy/jquerynoconflict.js
removed 6 empty script tag(s)
Execution time (in seconds): 0.11181807518005
10 years 7 months ago #4025 by bujinkanat
The gallery phocabar list is now working.
Should i chance the slideshow on the startsite?
Did you now a better slideshow that works?
