file JQuery conflict on my webpage
13 years 1 hour ago - 13 years 51 minutes ago #2092 by khalil
JQuery conflict on my webpage was created by khalil
I have a page on my website that loads 3 jQuery links, so one module is not working due to that.
May you please guide me how to let JQuery Easy solve this issue.
my link is
www.inocc.com/demos/inaash/index.php/2013-04-10-13-23-20/najaf
username:inaash
Thank you in advance
Last edit: 13 years 51 minutes ago by admin.
13 years 47 minutes ago #2096 by admin
Replied by admin on topic Re: JQuery conflict on my webpage
can you tell me which page?
12 years 11 months ago #2098 by khalil
Replied by khalil on topic Re: JQuery conflict on my webpage
Thank you for your fast reply.
the link i gave you is the page itself.
the module that is not working is the slideshow, where 2 white navigation arrows are.
12 years 11 months ago #2102 by admin
I was asking you because the page you listed has no jQuery library loaded.
ppc.safejqueryplugin.start.js
ppc.safejqueryplugin.end.js
jquery.tools.min.js
are not jQuery libraries.
You need to use jQuery Easy plugin to add jQuery (select jQuery and specify a version).
Moreover, $(document).ready(function() {
needs to be replaced.
Use 'fix document ready' from the advanced options.
Please let me know when you have done this :-)
12 years 11 months ago #2106 by khalil
Which version of jQuery am i supposed to specify?
$(document).ready(function(){
what should i replace it with?
what should i do with the 'fix document ready', just set it to yes?
Please help me a bit more here, because i am totally new to this.
12 years 11 months ago #2109 by admin
You have to find out which version of jQuery you need to use, I cannot find this for you. Go to your module's page or ask the developer himself. That also may be in the documentation of the module and/or its options.
If you want to be quick, just set version 1.7 and we will see what happens.
The only other thing you have to do is set 'fix document ready' to 'yes'. It will replace $(document).ready(function(){
for you.
