file JQuery conflict on my webpage
12 years 4 months ago #2112 by khalil
Replied by khalil on topic Re: JQuery conflict on my webpage
I did set 'fix document ready' to yes, and i did add jQuery and set version 1.7, but nothing changed :(
12 years 4 months ago #2113 by admin
Replied by admin on topic Re: JQuery conflict on my webpage
That is ok, this is a first step, I have to take a look once more.
12 years 4 months ago #2116 by admin
Ok, it seems like the module works with jQuery 1.6. You should change it in the plugin.
Now, I have never seen such code... the libraries needed for the module are called dynamically from javascript.
This is unfortunately making all changes obsolete at the Joomla level (and with the jQuery Easy plugin) as there is no possible control over it. I know what needs to be done but this requires changes of code in the module itself, which we will not go through since you are a beginner here.
I suggest you contact the developer of the module. If you cannot get help from him, I would suggest you use another slideshow.
