exclamation-circle Fatal error
11 years 4 months ago #3587 by wicklert
Fatal error was created by wicklert
Bought your component tonight and installed it. Same for the library.
Adding menu item and facing a fatal error.
Fatal error: Call to a member function addLink() on a non-object in /var/www/vhosts/<domain>.org/httpdocs/libraries/expose/admin/fields/colorpicker.php on line 29
Using Joomla v3.2.3.
Please advise.
Regards
Ed
11 years 4 months ago #3588 by admin
Replied by admin on topic Fatal error
Hello Ed,
there seems to be a conflict between the library 'syw' and the library 'expose'. For some reason, the wrong colorpicker.php is called, provoking this error.
At this point, I have to investigate why the component Trombinoscpe Extended is calling 'expose' rather than 'syw'.
I am assuming you downloaded and installed the library: www.simplifyyourweb.com/index.php/downlo...ategory/23-libraries
Please confirm. Thank you!
11 years 4 months ago #3589 by wicklert
Replied by wicklert on topic Fatal error
Hi Olivier,
I can confirm downloading and installing the library (lib_syw.zip), plugin is published.
Awaiting your advise.
Regards
Ed
11 years 4 months ago #3596 by admin
Ed,
could you tell me what is the component that installs the library expose/admin/fields/colorpicker.php ?
I have tried reproducing your issue but with no luck at this point.
Thank you.
11 years 4 months ago #3597 by wicklert
Hello Olivier,
Found out tonight that this is the component DJ-ImageSlider.
Came with the template.
Disabled plg_system_expose and can use your component without any problem. :)
Result: can't use the expose option in Slidershow any more....!!
Suggestions?
11 years 4 months ago #3598 by admin
I will install the plugin and see if I get conflicts.
Only then I will have a better idea on how to fix it.
The thing is, there is a colorpicker in Joomla! and Trombinoscope does not conflict with it, so I am wondering why it does with 'expose'.
