exclamation-circle Fatal error
11 years 4 months ago #3599 by admin
Replied by admin on topic Fatal error
By the way, this error should not affect the front end since it is only happening when showing color pickers in the administration. Once you have setup Trombinoscope to your liking, you can re-enable plg_system_expose and the site should work.
11 years 4 months ago - 11 years 4 months ago #3600 by admin
I installed DJ-ImageSlider and there is no plugin...
The plugin does come with your theme (ThemeXpert) and it seems like it is used for mega menus, not for the slider.
Last edit: 11 years 4 months ago by admin.
11 years 4 months ago #3601 by wicklert
Replied by wicklert on topic Fatal error
I assumed that the plugin plg_system_expose belongs to DJ-ImageSlider because it is one of the options within the component/module. :)
I am not using a ThemeXpert template but made by Joomzilla.
I will re-enable the plugin and will see what happens. I will let you know.
11 years 4 months ago #3604 by admin
The thing is, the problem comes from a colorpicker. Does the DJ-ImageSlider has a color picker in the parameter settings? I have not in the download I have.
I told you about ThemeXpert because it is what I have found when searching for the 'expose' system plugin.
