file Weblink Logos Pro does not work well like on the demo
3 years 3 months ago #5699 by luishorta
I have a problem when using your extension on Joomla 4.1.4 testing website on my local sever.
I create a menu Item and choose Menu Item Type is "Weblink Logos Pro >> Directory", and do the settings for it.
But when I open the menu item on the front-end, the page show nothing.
Can you tell me what can cause this problem?
3 years 3 months ago #5700 by syw
Ok; I see it's not an error.
Do you have images in your weblinks? This is necessary for the view to show items.
You should have a default logo in your configuration, at least as a start.
I hope this helps.
