file Comments change position
10 years 7 months ago #4054 by cealocanth
Comments change position was created by cealocanth
:dry: I have the comments changing position, margins and positions on each slide and I cannot find out why this would be happening. It seems like each slide has an individual style for it's comment box, but cant find where.
10 years 7 months ago #4056 by admin
Replied by admin on topic Comments change position
the content of each slide is distributed following a convention. For example, 'ne' will set the content in the up-right corner of the slide. This parameter is entered in each article that you use as a slide ('caption' parameter of the full article image section).
You will find all possibilities in the documentation (page 13).
Other than that, you may have CSS conflicts with your template or other parameters, but I will be able to help you on a live URL I can look at. If you don't want to post that URL to the forum, please send an email to [email protected]. Thanks!
