file Cant find images directory
12 years 1 month ago #2742 by fujau14
Cant find images directory was created by fujau14
hi
I keep getting this
Error
Folder does not exists
yet the folder is there any ideas what i am doing wrong
12 years 1 month ago #2744 by admin
Replied by admin on topic Re: Cant find images directory
do you have a URL I can look at? Are you running the trial version? What data source are you using?
If using 'images', the paths to your images need to be:
/myfolder/myimage.jpg for instance.
The path to the /images directory is added by the module.
