lightbulb-o Required: Item width
13 years 1 week ago #848 by Fischkopp
Required: Item width was created by Fischkopp
I installed the Latest News Enhanced Extended and it works very well but I´m a little bit confused about the "Required: Item width".
I have no idea what is meant by it and find no way to adjust the item width. So the animation can´t work.
Maybe you have a tip for me?
Many greetings from Germany
Manfred
13 years 1 week ago #849 by admin
Replied by admin on topic Re: Required: Item width
Hello Manfred,
thank you for your interest in the module!
Some animations need specific height and/or width in order to work properly (all news items need to be of the same size so that the animation stays fluid and does not flicker).
The item width is adjustable in the basic options under 'overall'.
Hope this is what you are looking for!
The following user(s) said Thank You: Fischkopp
13 years 1 week ago #851 by Fischkopp
Replied by Fischkopp on topic Re: Required: Item width
Hello Oliver,
thank you very much for your help!!!
Sometimes I´m really totally blind. The entry fields for height and width I had seen but the field for the item widht escaped me.
But now I have a new problem. I have chosen to display all categories and a max. display of 5 items entered but it is always displayed only 1 item. The following ads are empty
13 years 1 week ago #853 by admin
Do you use an animation for it?
If so, you can only see 1 item because the animation doesn't work. That may be a jQuery issue.
Do you see more that 1 item when the animation is off?
13 years 1 week ago #854 by Fischkopp
Oh, thanks, that's a good control function. Now I think I know why only one item is displayed. The site is still under construction and there are not yet filled all categories.
The module is really a powerful tool.
Thanks again and best regards. I wish you a good night (as late or early as it may be with you) ;)
13 years 1 week ago #857 by admin
Thank you (I am at US central time) :-)
Great that you like the module!
