file Upgrade to Extended
13 years 2 weeks ago #830 by admin
Replied by admin on topic Re: Upgrade to Extended
I don't see anything wrong in the code so far. Is there a way to disable jQuery for the swMenuPro module?
If not, maybe you will need to use jQuery Easy to sort this out. It will eliminate the extra library, the extra noConflict() code and hopefully solve your issue.
13 years 2 weeks ago #831 by gulam
Replied by gulam on topic Re: Upgrade to Extended
I disabled jquery in swmenupro and this seems to have helped.
Gulam
13 years 2 weeks ago #832 by admin
Great.
I will investigate further and make the proper fixes in the module so these issues don't arise later on for you or other users.
Thanks for your patience!
