file Scroll Animation Options / Styling
7 months 6 days ago #6128 by [email protected]
When using the scroll animation feature, the usual layout rules no longer apply e.g. 'Row / Center / Stretch'.  The slider stops using flex properties.  Can the stretch property, for example, still work for the scroll so that we can have fluid / dynamic heights?
Could the 'Visible' items be expanded on to allow for responsive breakpoints?
The move one at a time feature also results in a fast loop back to the start of the list, rather than a nice smooth continuous scroll.
Thanks in advance.
Mark
7 months 6 days ago #6129 by syw
Replied by syw on topic Scroll Animation Options / Styling
Hello Mark,
yes, the scripts take over some of the formatting. You may still be able to override some of the CSS but it may interfere with the script's functionality as it has to calculate widths and heights for functioning properly.
Which script are you using? The jQuery based or the pure javascript one?
Have you tried switching to see if one works better than the other for your linking?
Visible items are here to ensure you see as many elements as you wish when the module is extended to its biggest size. So if you allow 4 visible items, this is how many you should expect when fully 'spread' on the page. Which may still end up being 3 items if your items are too large.
The script then takes care of reducing the number of visible items as the container shrinks.
Sliders are outside scripts made available through the module and adapted to help make it easier for everyone to use. I am always looking for scripts that could improve the user experience.
