file Pagination next page does not go to top of next page
2 years 9 months ago #5792 by ians
Hi there,
I have installed LNE Pro on a new Joomla 4 website.
LNE is v 6.7.0
Joomla is v 4.2.5
All is fine and I have about 100 articles with pagination.
When I click the next page it moves on to the next group but the page doesn't scroll back to the top.
I can't see any settings to change this behaviour. Is there a fix?
Any help will be gratefully received :-)
Yours,
Ian
2 years 9 months ago #5793 by syw
Hello Ian,
when paginating to the next page, the page should reload with new data and start from the top of the page, which is the default behavior in a browser.
Could you give me the URL of the page so I can see this behavior?
Do you have pagination on another page with another component and checked if you get the same behavior as well?
2 years 9 months ago #5794 by ians
Hi syw,
thanks for your quick response
here the url itchycoopark.co.uk/london/case-studies
I dont have pagination elsewhere so cant really check
many thanks,
Ian
2 years 9 months ago #5796 by syw
Ian,
the problem is that you are using pagination on the module, which is meant for a small number of articles.
For proper pagination, you need to create a menu item of blog type for the component.
When using the modules, all articles are pre-loaded, which can be a problem on a large amount of items and a script is used for pagination.
2 years 9 months ago #5798 by ians
Many thanks indeed - that's fixed the pagination. However.... I had the left side pictures (head) level with the text and now they are showing higher than the title.
I think I've adjusted every setting to get the picture lower so it's all aligned but not getting anywhere.
Any pointers? sorry to be so stupid :-)
2 years 9 months ago #5799 by syw
No need to apologize, these are legitimate questions!
You can remove some margin above the title with a bit of CSS:
.lnep_blog form .newstitle { margin-top: 0; }
Just add this in the 'theme' tab, CSS override section.
