file 0 - String could not be parsed as XML
4 years 8 months ago #5378 by schulzdesign
Replied by schulzdesign on topic 0 - String could not be parsed as XML
Thank you very much.
The email for you is out.
Sincerely,
Thorsten
4 years 8 months ago #5379 by syw
Replied by syw on topic 0 - String could not be parsed as XML
Mystery solved.
You have added 'vun-netzwerk' to the list of image attributes, which is incorrect.
The value of that field should be something like:
data-pin-nopin="true"
If you intended to use 'vun-netzwerk', it should be
vun-netzwerk="something value"
or
some_attribute="vun-netzwerk"
4 years 8 months ago #5380 by schulzdesign
Thank you very very much.
However that entry got there. Presumably it was confused with the ALT attribute.
Thank you again for the excellent support.
Sincerely,
Thorsten
4 years 8 months ago #5381 by syw
You are welcome Thorsten!
