file Some settings cannot be saved
  • Сергей_Матюнин
  • Сергей_Матюнин's Avatar Topic Author
  • Offline
6 years 7 months ago #5120 by Сергей_Матюнин
Some settings cannot be saved was created by Сергей_Матюнин
Options "Load icons font" and "load font IcoMoon" doesn't saves. I set "No" to both, click "Save" and I see "Yes (default)" again.
6 years 7 months ago #5121 by syw
Replied by syw on topic Some settings cannot be saved
does this happen on module instance, menu items or global configuration (or on all cases) ?
Try and save the global configuration parameters of the extension first.
'Load icon font' is one of those parameters that is checked against global (shared) parameters, so maybe for some reason your Joomla environment does not find the global settings.
Let me know if that fixed it. Thanks!
