file Error 500 after choosing pictures for head
7 years 1 week ago #5053 by fshirondelle
Error 500 after choosing pictures for head was created by fshirondelle
Hi all,
recently I installed Latest News Enhanced Pro 4.4.1 on Joomla 3.8.7.
Everything is working fine until the moment I change the head typ in the layout-setting to "image from content". Afterwards I get a 500 error (see image attached).
The calendar view however is working fine
Do I miss any settings?
Thanks for your help & best regards!
7 years 1 week ago #5054 by syw
no matter your settings, you should not get a 500 error, therefore you did not miss anything.
Sometimes the additional library gets corrupted on update and it may just be a matter of re-installing it.
simplifyyourweb.com/downloads/syw-extens...eb-extension-library
If you are still getting errors, try and change the advanced settings for the image caching. Maybe the directory where thumbnails are set to be located doesn't have the proper rights.
If all fails, contact me directly with your site credentials so I can take a look. Thank you!
[email protected]
