file Item URL issue
8 years 7 months ago #4860 by severdia
Item URL issue was created by severdia
I'm trying to get the LNE Pro module to use item URLs based on the Joomla menu item pointing to the category of articles. Instead the module is using the current menu item. For example, the articles displayed in the module are all in one category and there is a Category Blog menu item posting to the category so the URLs are correct, like:
/people/joe-smith
/people/mary-wilson
When clicking that menu item and viewing the articles within it, I get the correct URLs like above. But when viewing those same articles within the module, they are inheriting the routing of the current menu item (whatever page/menu item the module is visible on). Like:
/new-menu-item/submenu-item/joe-smith
/new-menu-item/submenu-item/mary-wilson
They should inherit from their parent category/menu item. Is there a setting somewhere that will fix this or allow me to choose a menu item for correct routing?
8 years 7 months ago #4861 by syw
Replied by syw on topic Item URL issue
you can force the item id ('force item id' parameter) in the 'advanced' tab of the module (assuming you have the latest version). You may try that and see if it helps.
8 years 7 months ago #4862 by severdia
Replied by severdia on topic Item URL issue
Yes, that worked. Thanks!
8 years 7 months ago - 8 years 7 months ago #4863 by syw
Wonderful :-) . You are welcome !
Last edit: 8 years 7 months ago by syw.
