file tag not showing in selection listbox
9 years 3 months ago #4713 by imma
Is it possible that, if a tag is created but no item is yet so labeled, the tag does not show in the selection listbox?
9 years 3 months ago #4714 by syw
Replied by syw on topic tag not showing in selection listbox
Hello Imma,
in the module's configuration, tags only show if associated with an article. If a tag is created (with no association to an article), it won't show.
Are you asking you would like to be able to select a tag that is not yet associated?
The following user(s) said Thank You: imma
9 years 3 months ago - 9 years 3 months ago #4715 by imma
Replied by imma on topic tag not showing in selection listbox
syw wrote: in the module's configuration, tags only show if associated with an article. If a tag is created (with no association to an article), it won't show.
Indeed.
syw wrote: Are you asking you would like to be able to select a tag that is not yet associated?
Well, this was my logical expectation as I was preparing a module instance to show items with a new tag; but I can think of use cases where the current approach is more convenient, so take it with a pinch of salt. Knowing the behavior, I can live with it.
Last edit: 9 years 3 months ago by imma. Reason: paragraph spacing
9 years 3 months ago #4716 by syw
Actually, it made me re-think about that restriction and I will remove it. There are cases where it would be nice to be able to select a tag that is not yet associated with articles.
Therefore this restriction will be lifted starting with v3.0.2 of the module (a couple days away).
