check Wrong layout before animation starts
9 years 6 months ago #4488 by marcin7
hi Olivier,
I have configured one module to be displayed with animation. It looks ok but there is one optical issue. Before the animations starts after the page is loaded (it takes one or 2 seconds) the module is displayed a "classic way". After those 2 seconds the animation starts ant the module is being "rebuilt".
How can I avoid this effect so that the module is displayed from the beginning with the same layout as it is when the animation starts.
Module configuration:
Visible Items - 1
Animation - Scroll
Move - one at time
See screenshots:
lnee-1 - immediately after the page is loaded
lnee-2 - after 2 seconds once animation starts
thanks in advance and best regards
Marcin
9 years 5 months ago #4490 by syw
Hello Marcin,
what version of the module are you using?
This behavior should be fixed in v2.2. This is a problem with the loading of the jQuery script.
If you did not, please update to v2.2 and let me know if the problems remain. Thanks!
The following user(s) said Thank You: marcin7
9 years 5 months ago #4491 by marcin7
hi Olivier,
thanks. updating to 2.2 solved the problem !!
thanks a lot
Marcin
9 years 5 months ago #4492 by syw
You are welcome Marcin!
