check src images after restore site
10 years 2 weeks ago #4372 by admin
Replied by admin on topic src images after restore site
You are welcome.
Where are the pictures in the articles then? in the intro image? The full image?
For instance, the article www.shaiya.com.ph/community/news-updates...atch-notes-8-25-2015 does not contain any image when going into 'read more'. It does not show intro or full image either when I look at the article.
The module, as far as I can see, does not find an image. It is not that it cannot show them, it just does not find any.
What is the 'head type' selected in the module ('Layout' tab)?
Have you tried adding a default image in the 'Head:image' tab?
10 years 2 weeks ago #4373 by jatsjames
Replied by jatsjames on topic src images after restore site
Thanks.
And Yes it's only on the intro image.
All thumbnails still intact in /tmp folder.
FYI. Before I enable SEF and Rewrite Rules, all is working fine. I may need a rewrite rule to allow images on /tmp folder to show.
10 years 2 weeks ago #4374 by jatsjames
My second option is to try reinstalling on top of it, does it remove the data?
10 years 2 weeks ago #4375 by admin
You have another option:
in the latest module versions, you have the possibility to change the /tmp path to the /images path, which is not restricted.
That may fix your problem.
Re-installing (without uninstalling first) does not loose data.
10 years 2 weeks ago #4376 by jatsjames
Thank you so much for the quick and precise reply.
Let me try the options suggested and get back for a working solution.
10 years 2 weeks ago #4377 by jatsjames
After I installed the version 2.0.2, picture was showing but path was incorrect..somehow I messed up.
Can you check the attach file and please help..
