file CSS is not loaded when LNEE is loaded in a module
11 years 8 months ago #3729 by CasperT
No, I'm not using any tweaking or minifing of the CSS. The only enhancement I use is GZip and cache, which shouldn't affect loading of the CSS.
If needed, you can get admin access and take a further look.
Just to be clear, the LNEE module is loaded inside the footer (custom HTML module) using {module modulenumber} by Modules Anywhere from NoNumber.
And I'm using newest release of LNEE (1.4.4)
11 years 8 months ago #3730 by admin
Thank you for the clarifications.
Please send your admin access credentials to [email protected]. Thank you!
11 years 8 months ago #3731 by CasperT
The problem is now fixed and after Olivier's help, it turns out it wasn't LNEE which caused the problem, but Modules anywhere that had some restrictions on how modules inside Custom HTML modules should be loaded. The Custom HTML module needs to have "prepare content" enabled for it to load the scripts from the loaded modules inside of the custom HTML module.
I apologise for the inconvenience - and once again thanks for the quick support Olivier.
11 years 8 months ago #3732 by admin
You are welcome Casper!
