file Date range problem
12 years 1 week ago #3576 by edgerunner
Date range problem was created by edgerunner
When i set a range display, block does not appear on my site. When i switch off this, it is ok. Could you help me ?
www.sport-auto-passion.ch
12 years 1 week ago #3577 by admin
Replied by admin on topic Date range problem
that may just be a configuration issue.
What are your basic settings for 'date' and the date range parameters? Have you tried the 'when no date' setting set to 'show before' or 'after'?
Are you sure the module does not show just because no date falls into the date range?
You can add screenshots here or send them to me at [email protected]
12 years 1 week ago #3578 by edgerunner
Replied by edgerunner on topic Date range problem
I tried "when no date" setting but it does not work.
I published1 to 5 posts every day so there always something in the date range. Here is screenshots with date range ; screenshots 1 & 2 "on" screenshots 3 & 4 "off"
Fred
12 years 1 week ago #3579 by admin
Hello Fred,
I have tried reproducing your issue but it does work on my test site, which is annoying :-)
Could you please send me a screenshot of one of the article publishing parameters (an article that should show) ?
Could you try the module when emptying the field 'nombre maximum' ?
12 years 1 week ago #3580 by admin
Fred,
I went through the code and I think there is a bug in the module (the number of items is limited BEFORE the date range is applied). So the test with 'nombre maximum' should confirm it. Let me know, I have prepared a bug fix release. Send me an email and I will send you the update for you to test.
12 years 1 week ago #3581 by edgerunner
So i tried to empty the field "Nombre Max " Here is what i get (screenshot 5 )
I joins screenshots of my last article publishing parameters
Fred
