question-circle LNEE - Pagination
12 years 5 months ago #3396 by mgdale
LNEE - Pagination was created by mgdale
I'm trying to make pagination work on LNEE. I've downloaded and installed the "Fade" animation module, but still I just get 2 arrows (left and right, stacked) showing on the frontend.
Any ideas what might be wrong? What do you need in order to help?
Thanks. :)
12 years 5 months ago #3397 by admin
Replied by admin on topic Re: LNEE - Pagination
I cannot really tell without a live URL, but check if you have jQuery enabled, that may be the problem (or if there is a javascript error).
Also make sure you have checked the 'configurations' section of the documentation that lays out all required fields for your animation to work.
12 years 5 months ago #3398 by mgdale
Replied by mgdale on topic Re: LNEE - Pagination
Is it possible to send this to you private as it is behind a members only section I cannot post publicly.
12 years 5 months ago #3399 by admin
Of course, send the credentials and URL to [email protected].
