file Styles doesn't work
13 years 3 weeks ago #1916 by gallus
Styles doesn't work was created by gallus
I bought yesterday LNEE but I can not run the styles.
I published the form in different positions and even tried to change the template, but the result is always the same, regardless of the style that required I get a display that you can see.
Could you help me?
Site
May I eliminate the pagination to show exactly only the latest 5 news?
Regards
gallus
13 years 3 weeks ago #1920 by admin
Replied by admin on topic Re: Styles doesn't work
the problem is that the stylesheets are not applied to the module. You will have to check the file permissions of the styles.css.php files (several of them) throughout the module. Please refer to other posts on that.
If you do not need pagination, turn off animations (set them to none) and just add '5' to the 'count' field in the basic parameters.
