exclamation-circle mod_latestnewsenhanced accordion layout
5 months 4 weeks ago #6132 by [email protected]
How can I get the 1st one to always be closed like the others? Then when clicked it will open.
5 months 4 weeks ago #6133 by syw
Replied by syw on topic mod_latestnewsenhanced accordion layout
you have to override the module's layout in your template.
The lines to change (if using Bootstrap 5):
class="accordion-button<?php echo 0 === $i ? '' : ' collapsed' ?>"
Replace with
class="accordion-button collapsed"
And
class="accordion-collapse collapse<?php echo 0 === $i ? ' show' : '' ?>"
Replace with
class="accordion-collapse collapse"
The following user(s) said Thank You: [email protected]
