file Links not working
3 years 1 week ago #5925 by Beachalog
Links not working was created by Beachalog
I've got several different Latest News Enhanced Pro modules on my site at www.thefencepedia.com
However, when you try to click the links, it shows some strange url that looks like www.thefencepedia.com/#slide_253_244 and doesn't actually open the link.
Any ideas how I can make the links actually work like links?
3 years 1 week ago #5926 by syw
Replied by syw on topic Links not working
you are using the accordion layout; you should use the default layout instead.
The accordion layout uses the title as a tab, then shows the content when clicked on. The link you see is the link to the content. However, it does not work here because some styles/scripts are missing.
simplifyyourweb.com/documentation/latest...st-of-options/layout
Make sure the extension is compatible with Bootstrap 5 (in the advanced tab) . That may fix the accordions (if you keep it).
The styles are also not properly loaded on the pages. /cache/mod_latestnewsenhancedpro/style_...
don't get the proper mime type for some reason.
Then you have other issues, like the content disappearing because of tooltips. See here when you get to it: simplifyyourweb.com/documentation/tutori...s-after-a-mouse-over
