file problem - jQuery Easy Profiles
5 years 4 months ago #5233 by Slavek
problem - jQuery Easy Profiles was created by Slavek
Hi, I would like to buy jQuery Easy Profiles. I'm using thefree version, but I still have errors in the code.
jdb.noconflict.js? 1dbf32ee86a4b664c1565de2df8a2f7b: 1Uncaught TypeError: $ .noConflict is not a function
    at jdb.noconflict.js?1dbf32ee86a4b664c1565de2df8a2f7b: 1
bootstrap.min.js? f8ef2ee47b203f13351953e0e4a00ea7: 6Uncaught Error: Bootstrap's JavaScript requires at least jQuery v1.9.1 but less
than v4.0.0
    at bootstrap.min.js?f8ef2ee47b203f13351953e0e4a00ea7: 6
(index): 589 Uncaught ReferenceError: refreshJDLightbox is notdefined
    at (index): 589
(index): 599 Uncaught ReferenceError: refreshJDLightbox isnot defined
    at (index): 599
(index): 609 Uncaught ReferenceError: refreshJDLightbox isnot defined
    at (index): 609
(index): 619 Uncaught ReferenceError: refreshJDLightbox isnot defined
    at (index): 619
(index): 629 Uncaught ReferenceError: refreshJDLightbox isnot defined
    at (index): 629
(index): 639 Uncaught ReferenceError: refreshJDLightbox isnot defined
    at (index): 639
(index): 649 Uncaught ReferenceError: refreshJDLightbox isnot defined
    at (index): 649
VM7738: 1 CreativeSlider v6.6 initialized
VM7738: 1 Find updates and docs @http://docs.offlajn.com/creative-slider
Could you help me?
Thank you.
5 years 4 months ago #5234 by syw
Replied by syw on topic problem - jQuery Easy Profiles
Hello Slavek,
purchasing jQuery Easy Profiles gives you more troubleshoot options and adds full support. Getting the free membership gives you full support as well.
That said, you probably can already fix these issues with the free version (I can point you in the right direction).
Sometimes, reading the errors you get can give you clues.
For instance:
Bootstrap's JavaScript requires at least jQuery v1.9.1 but less than v4.0.0
Therefore I would suggest checking what version of jQuery you are using with the free jQuery Easy plugin.
Then you may want to try the 'no conflict' options that the plugin offers. In this case, I am not sure what the best tweaks are, I would need to see the page 'live' to assess the best course of action.
If you need fixing in just a few pages of your site, there are options you can use to restrict the range of action of the plugin. If you need different fixes on different pages, the Profiles version is the way to go.
5 years 4 months ago #5235 by Slavek
Replied by Slavek on topic problem - jQuery Easy Profiles
Hi Syw, the page is here
zus-kostelec.platimmalo.cz/
Thank you for the advice.
We will be happy to buy your extension;)
5 years 4 months ago #5236 by syw
I have received your email and replied with additional information. Let me know how it turns out :-)
