file Picture
13 years 3 months ago #503 by brilla
Picture was created by brilla
Is there a way to not show picture or make thumbnail smaller? The phone number won't fit across the module because the template I am using has a smaller width than picture and phone will fit across. Thanks!
13 years 3 months ago #505 by admin
Replied by admin on topic Re: Picture
I suppose you are talking about the trombinoscope module.
It is easy not to show the pictures, just use CSS and the 'display: none' property on the .picture class.
The following user(s) said Thank You: brilla
13 years 2 months ago #623 by brilla
Replied by brilla on topic Re: Picture
Ok, so I changed style.css.php
.trombinoscope_<?php echo$suffix; ?> .personpicture {display:none;}
The picture is gone but the text didn't move over so only partially solved my problem :) Can you further advise?
13 years 2 months ago #624 by admin
You need to eliminate the margin by doing:
.personinfo.left {
margin-left: 0!important;
