exclamation-circle Popup not working
13 years 4 months ago - 13 years 4 months ago #1406 by Tzimbe
Popup not working was created by Tzimbe
I'm making a website for a hockey team. I'd like to use a pop up window to show a small interview of every player. Anyway the pop up doesn't seem to work.
The nastolankiekko.com/test . If you click a link that says "Koko profiili" the popup window opens up as a blank. Can someone help me?
Last edit: 13 years 4 months ago by admin.
13 years 4 months ago #1409 by admin
Replied by admin on topic Re: Popup not working
there is an issue finding the contact id and all links get an id of 0. This is something I need to address.
What version of Joomla! are you using? Do you have SEO/SEF tools enabled (from Joomla! or another admin component)?
I need to point out that when the link will work, it will show the full contact page of the hockey player, not just the interview you may have included in the contact's page at the admin level (the popup shows exactly what should load in a standard contact page under Joomla!).
13 years 4 months ago #1413 by Tzimbe
Replied by Tzimbe on topic Re: Popup not working
my friend @Tomi_K_Rinne was able to solve this problem. The problem was with my cheap:) template. My template's component.php file didn't render in the right way..
Thanks anyway!
13 years 4 months ago #1414 by admin
Great news :-) Glad you were able to solve it!
