file Using fields a Trombinoscope Contact
4 years 1 week ago #5641 by webmaster-cognin
Using fields a Trombisnoscope Contact was created by webmaster-cognin
Hello
I am using Yootheme over Joomla and Trombisnoscope Contact .
I would to know if it is possible to filed like First Name, Last Name or User field is a form of Yootheme like a list of Last Name - First Name pointing to an URL specify in a user field of TC
Thank for your Help
4 years 1 week ago #5642 by syw
Replied by syw on topic Using fields a Trombinoscope Contact
I am not sure I understand your question.
Do you want to link users from a YooTheme form to Trombinoscope Contacts?
Trombinoscope Contacts only works with the Contact component, not the User component. Eventually, TC can get to a user if a contact is linked to that user.
Can you clarify what you need? Thank you!
4 years 1 week ago #5643 by webmaster-cognin
Replied by webmaster-cognin on topic Using fields a Trombinoscope Contact
For examples
If I create an article and can I create an automatic list with all the users and there web site ?
Thanks you
4 years 1 week ago #5644 by syw
Yes, you can include a Trombinoscope Contacts module inside an article, listing all contacts with their website.
Create the TC module, then go to your article. In the article's editor you should see a button or a link allowing insertion of modules - just select the one TC module you have created.
This will add the syntax { loadmodule XX } to your article. In the public side of the site, you will see the article with the list of contacts (the way you have set it up in TC).
In that case, the TC module does not need to have a specific template position.
Hope this helps!
The following user(s) said Thank You: webmaster-cognin
