file Configuration two columns
9 years 1 month ago #4621 by gabber3000
Configuration two columns was created by gabber3000
I just upgraded to the latest version Trombinoscope.
Unfortunately I can not configure my most layout in two columns.
What are the steps to set the layout to two columns?
Currently I see only one column. See here:
www.fitness-factory.it/istruttori-affiliati.html
thank you.
9 years 1 month ago #4624 by syw
Replied by syw on topic Configuration two columns
one reason for this not to work is because you are missing the stylesheets.
Please look at the troubleshooting page: www.simplifyyourweb.com/documentation/tu...yling-and-animations for help. The on-the-fly CSS creation is failing because of missing permissions.
To get two columns, you need to set the item width to something like 48% (the extra 2% are for margins).
9 years 4 weeks ago #4628 by gabber3000
Replied by gabber3000 on topic Configuration two columns
Thanks for the advice. I solved it by changing the permissions from 644 to 755 for the following files:
style.css.php
stylemaster.css.php
stylemaster.js.php
9 years 4 weeks ago #4630 by syw
Great! Thanks for the feedback.
