file "Empty solution not allowed"
4 years 1 week ago #5525 by amemiya
"Empty solution not allowed" was created by amemiya
I have been used "Rescue Me ReCaptcha".
I know that I have to use Joomla3.* and I use Joomla3.* at some website.
But I have to use 2.5 at some website by all means, so the product you made has saved me. Thank you!
Today I checked site after a long time and I found error message "Empty solution not allowed" . I use Rescue Me ReCaptcha 1.0.2.
Do you have information about this?
Thank you
4 years 1 week ago #5530 by syw
Replied by syw on topic "Empty solution not allowed"
this usually happens when the site and secret keys are not the right ones or are no longer valid and they need to be re-generated (at Google www.google.com/recaptcha). You may want to double-check your reCaptcha keys, as Google gives different keys for different versions of reCaptcha.
Also make sure there is only one reCaptcha on the pages where you have it enabled.
4 years 3 days ago #5532 by amemiya
Replied by amemiya on topic "Empty solution not allowed"
As you advised, I reacquired eCAPTCHA-key v2 and registered it in the plugin. But unfortunately, the error display did not change.
I also confirm that there is only one reCaptcha on this page.
For the time being, I'm going to run the site without the reCaptcha feature, but I'll continue to try ways to avoid the error.
Thank you for your advice. Thank you very much!
4 years 3 days ago #5533 by syw
I don't have any other suggestion for now, sorry...
The following user(s) said Thank You: amemiya
4 years 2 days ago #5536 by amemiya
Thank you for your suggestion.
When I was looking for the cause of the error again, I realized my misunderstanding.
The plugin download page contains an important notice that MooTools 1.4.5 files must be copied from Joomla 3. * to work. I misunderstood that installing the plugin v1.0.2 would also update MooTools 1.4.5 files.
After manually copying and configuring MooTools 1.4.5 files, the error disappeared and reCaptcha is now working properly.
It was my mistake. sorry.
I really appreciate your suggestions. thank you!
4 years 2 days ago - 4 years 2 days ago #5537 by syw
No worries, glad you go it working!
I did not mention MooTools because usually you get a different error than "Empty solution not allowed" when you get a conflict.
So, good that you went back to the download page!
Thanks for the feedback.
Last edit: 4 years 2 days ago by syw.
