file Dancing around integration
13 years 3 days ago #2074 by cader
Dancing around integration was created by cader
Hello Olivier,
On first sight I see you have enjoy in web helping.
Your tutorials about jQuery in Joomla are the best on the Net.
I am absolute beginner in jQuery, so, can you make some kind of 'Print Screen' tutorial, the Tree positions of jQuery – folders and files in Joomla, please?
My Joomla is in warp framework. After installed jQuery Easy Plugin, I am still dancing around integration.
Thank you.
Many Regards
13 years 3 days ago #2076 by admin
Replied by admin on topic Re: Dancing around integration
thank you for your feedback, I am glad my tutorials help you out!
To make sure I understand your request: you need an explanation on where to put jQuery library files into Joomla! locally?
Correct me if I am wrong :-)
13 years 3 days ago #2078 by cader
Replied by cader on topic Re: Dancing around integration
Yes, is it possible some kind of Image Tutorial - the Tree of folders and files (and how the files .xml, .php look like inside?)
Visual tutorial jQuery in Joomla - for Dummies.
Thank you for rapid fast answer.
13 years 2 days ago #2079 by admin
I will see how I can do this :-)
13 years 2 days ago #2080 by cader
You can publish 'All about Modern integrations in Joomla' - short Ebook or paper format.
Many Regards
