file jquery.noConflict.js resists to Strip No Conflict.
13 years 3 days ago #2073 by lliseil
First, thank you! I finaly could make use of a jquery scripts-heavy template on a client's website with thanks to jQuery Easy.
Oliver is it alright that option 'Strip No Conflict Code' set to 'yes' won't remove script jquery noConflict? e.g.
<script src="/components/com_virtuemart/assets/js/jquery.noConflict.js">
Joomla! 2.5.9, Virtuemart 2.0 website.
This is not an issue here, rather a feedback.
13 years 3 days ago #2075 by admin
thank you for the feedback.
Yes, it is normal that the script is not taken out.
I removed this feature a while back for performance purposes. This will be back in v1.5.0 (coming really soon) as more and more extensions use that way of entering noconflict code into pages. Right now, you have to use the 'strip remaining script' option to do that.
