file load jQuery from local
13 years 11 months ago #413 by sillybug
load jQuery from local was created by sillybug
Well, since I often work on my laptop, and many times do not have internet acceess, it would be great to include a local copy of jQuery library and an option to load it from google/local
13 years 11 months ago - 13 years 11 months ago #414 by admin
Replied by admin on topic Re: load jQuery from local
I totally understand the problem...
When I first released the plugin, I wanted to keep it simple and light and differ from the other plugins out there... I kept adding features to accommodate most cases and it turns out the plugin becomes the most complete of them all.
Adding local copies of jQuery is problematic. It means all versions need to be available locally, as well as jQuery UI versions and all CSS styles that go with it...
I have to see how I can keep the plugin simple and manageable for maintenance purposes in adding this feature...
Thank you for your suggestion!
Last edit: 13 years 11 months ago by admin.
