file Advanced Option - Enable/Disable jQuery.noConflic
13 years 6 months ago #213 by admin
Thank you Ben, this is really helpful.
I have to see what I can do in those cases...
13 years 6 months ago #236 by admin
Hello Ben,
can I use your email address (the one you registered with) to send you a beta version of jQuery Easy so you can test it out and see if it actually helps with your jQuery problems?
