file sobipro jQuery Easy Widgetkit
12 years 11 months ago #989 by angel
sobipro jQuery Easy Widgetkit was created by angel
sorry for contact you again with a similar problem about sobipro and widgetkit
galice.net/es/restaurantes
I can't find the solution for this conflict, I installed the jquery easy but in this case nothing change
can you help me please :whistle: :(
12 years 11 months ago #990 by admin
Replied by admin on topic Re: sobipro jQuery Easy Widgetkit
Hello Angel,
the problem comes from your template that adds its own sets of Mootools and jQuery files. Although it helps the template to keep control over the way libraries are loaded, it is a nightmare once other components add there own libraries... The one thing I would suggest here, if you cannot disable MooTools and jQuery from your template, is to add the line:
/cache/template/gzip.php?jquery-77218f6a.js
to the list of remaining scripts to strip.
12 years 11 months ago #991 by angel
Replied by angel on topic Re: sobipro jQuery Easy Widgetkit
hi
I put the code but nothing change, is curious because the other conflicts that I had worked now , the problem is more with sobipro I think
I selected the jQuery v.1.8
and theme smoothness
its ok?
12 years 11 months ago #993 by admin
You need to look at your source code once you have made modifications to make sure they occur as expected.
I can see that the line I asked you to add is still there for instance.
Do you reall need jQuery UI? Unless you are replacing jQuery UI for a component, you don't need it here.
As far as knowing if you have the right version of jQuery, you have to check every component that uses jQuery to make sure they work with that version.
