file I am getting the following warning when enabling j
13 years 6 months ago #997 by admin
Yes, the jQuery versions are consolidated now. You may have to test what happens if you set 'add no conflict code' to 'none' because now you have 2 of them. But if it works for you like that, I would leave it as it is.
13 years 6 months ago #998 by ctdcreative
Thanks Oliver
13 years 5 months ago #1092 by admin
A user had a similar problem.
It turned out it was a side effect of the Virtuemart discount module (2.0.8c).
13 years 2 months ago #1602 by jlilio
In my case, I switched from https to http on the front end and the issue disappeared.
Hope it helps someone.
13 years 2 months ago #1603 by admin
Thank you for your answer!
13 years 5 days ago #2062 by admin
I have finally come to the bottom of this issue. The answer is very technical.
The jQuery Easy plugin uses the character # to enclose regular expressions. An error in the regular expression finding the noConflict() code declarations was making the plugin select sometimes the few lines preceding the noConflict() code. If it happened that the 'extra' selection would contain a # character, it would trigger a preg_match error.
The version v1.4.3 will try and address this issue.
Thank you Cyril for making your test site available and give me the opportunity to finally understand these random errors (not so random after all).
