file problem with "disable in pages"
12 years 11 months ago #979 by alessio31183
problem with "disable in pages" was created by alessio31183
Hallo,
I have a problem with disable in pages option.
When I insert a full link with http://... the disable option work correctly. But when I try to insert a multiple pages in only one address with "*/product" path the plugin don't disable correctly. I can't insert all pages path because there are many and many link to insert in disable option of plugin. I need to use a multiple pages path option with a "*/....." option but this is not work.... Please help me....
Thanks bye
12 years 11 months ago - 12 years 11 months ago #980 by admin
Replied by admin on topic Re: problem with "disable in pages"
can you make sure there is no space or any other character before the '*' as it looks for the star at position 0? Thanks.
Well, discard my question, the paths are trimmed by the plugin anyway...
Can you give a screenshot of your advanced parameters and an example of links containing /product?
Last edit: 12 years 11 months ago by admin.
