file Custom themes
13 years 1 week ago #850 by rgirona
Custom themes was created by rgirona
Hi there,
First of all thanks for such an amazing plugin.
I am using the tab feature of jquery ui with a custom theme. I have tried to develop a new custom theme withjquery ui roller and place the files under /library/jquery/custom (jquery-ui-1.8.23.custom.css and the images folder)
Then I set up the custom theme on the plug-in. Theme to custom/local and Custom/Local Theme Path to /library/jquery/custom, but it doesn't work, and it does for whatever theme: base, redmon, etc.
Do you know pls if I am doing anything wrong or I am missing anything?
Thans very much in advance,
Ramón Girona
13 years 1 week ago #852 by admin
Replied by admin on topic Re: Custom themes
Hello Ramon,
the custom path should be '/library/jquery/custom/' if you created a specific 'library' folder into your website configuration or '/libraries/jquery/custom/' if you use the existing one. Then make sure the file is called 'jquery-ui.css'. I am making changes as we speak to make that process a little simpler (watch for a 1.3.0 beta version in the next couple days) with LOTS of improvements.
Hope this helps for now!
13 years 1 week ago #855 by rgirona
Replied by rgirona on topic Re: Custom themes
Following these instructions It doesn't work. I have attached screenshots with configuration and the web site (on my laptop). If you need any additional information, pls let me know.
Thanks,
Ramón
13 years 1 week ago #856 by rgirona
Replied by rgirona on topic Re: Custom themes (screenshots)
The attached file with the screenshots
13 years 1 week ago #858 by admin
Replied by admin on topic Re: Custom themes (screenshots)
Ramon,
the previous post has no attached images.
Thanks for trying again.
You may also write me at [email protected].
