file How do i Start using JQuery Easy ?
13 years 7 months ago #77 by EnergyBlazar
How do i Start using JQuery Easy ? was created by EnergyBlazar
Hello guys,
I have just installed the plugin JQuery Easy, but i am a bit confused about how to use it.
Can anyone link me to a documentation, tutorial or anything that can help me get started
Also one more thing i am using JOOMLA 1.7 + SEBLOD. The real reason was for using jquery is to create a AUTOCOMPLETE WIZARD for a text field that i created using SEBLOD. Is it possible to implement autocomplete to such a field ?
Thank you in advance for your time and response :)
13 years 7 months ago - 13 years 7 months ago #80 by admin
Replied by admin on topic Re: How do i Start using JQuery Easy ?
there is no documentation about the plugin because its purpose is just to consolidate jQuery versions used on a website, when extensions use jQuery extensively, so there are no multiple calls to multiple jQuery libraries anymore. There are a couple links on this website on the download page.
If you just want to add jQuery to your website, you can use this plugin as well. It will just add the proper libraries to your template.
There are a lot of autocomplete jQuery plugins out there, you should try some out before creating your own. You may just find what you need.
To add javascript code without messing up your template, I would suggest this extension: extensions.joomla.org/extensions/edition...ode-in-modules/17122 . It is a great complement to jQuery Easy.
Last edit: 13 years 7 months ago by admin.
13 years 7 months ago #86 by EnergyBlazar
Replied by EnergyBlazar on topic Re: How do i Start using JQuery Easy ?
Thanks will try out you suggestion and revert back ...:)
13 years 7 months ago #87 by EnergyBlazar
Hello one more question
After installation of this if i directly insert jquery in the editor will it work ?
13 years 7 months ago #88 by admin
As long as you have the jQuery library included in your template, it will work, yes.
