file sobirpo wiidgetkit
13 years 1 month ago #676 by angel
sobirpo wiidgetkit was created by angel
some time aogo you give me a solution for my problems but now after some updates I lost the control of the jquery easy
I have several problems and I cant solved
can you help me to configurate the plugin?
13 years 1 month ago #677 by admin
Replied by admin on topic Re: sobirpo wiidgetkit
I don't see any problematic issue on the homepage so far, except that I don't like when the template loads MooTools on its own. That should be done by Joomla!. Since the template handles MooTools, jQuery Easy does not look for it. Anyway, you should be fine like that.
Let me know where you find problems and make sure you have the latest version of the plugin (1.2.1).
13 years 1 month ago #678 by angel
Replied by angel on topic Re: sobirpo wiidgetkit
Thanks a lot for your answer
here I have a problem with the geomap
galice.net/es/dormir/turismo-rural/668-A-Painza-3
and I don't know if it's posible to change how the template uses mootools or if it's posible to changed it
