file Advice?
13 years 2 months ago #627 by geoffr
Advice? was created by geoffr
Several users of our site have reported some features (e.g. upload) not working. I have been directed to try your plugin, as our YooTheme template shows the following "potential issue". Are you able to advise what settings I should use for your plugin?
Thanks very much!
Geoff
System Check1 potential issue(s) detected.
Multiple jQuery Libraries found. Please make sure these don't conflict each other.
/components/com_community/assets/easytabs/jquery.easytabs.min.js
/components/com_community/assets/featuredslider/jquery/jquery.easing.1.3.min.js
/components/com_community/assets/featuredslider/jquery/jquery.mousewheel.min.js
/components/com_community/assets/featuredslider/sliderkit/jquery.sliderkit.1.8.js
/components/com_community/assets/imgareaselect/scripts/jquery.imgareaselect.js
/components/com_community/assets/imgareaselect/scripts/jquery.imgareaselect.min.js
/components/com_community/assets/imgareaselect/scripts/jquery.imgareaselect.pack.js
/components/com_community/assets/joms.jquery.js
/components/com_community/assets/joms.jquery.mobile-1.4.2.js
/components/com_community/assets/joms.jquery.mobile-1.4.2.pack.js
/components/com_community/assets/joms.jquery.pack.js
/components/com_community/assets/jquery-1.3.2.pack.js
/components/com_community/assets/jquery-ui-tabs.min.js
/components/com_community/assets/jquery.tablednd_0_5.js
/components/com_community/assets/jquery.tablednd_0_5.pack.js
/components/com_community/assets/multiupload_js/jquery.plupload.queue/jquery.plupload.queue.js
/components/com_community/assets/multiupload_js/jquery.ui.plupload/jquery.ui.plupload.js
/components/com_community/assets/tipsy-0.1.7/src/javascripts/jquery.tipsy.js
/components/com_jce/editor/libraries/js/jquery/jquery-1.7.1.min.js
/components/com_jce/editor/libraries/js/jquery/jquery-1.7.2.min.js
/components/com_jce/editor/libraries/js/jquery/jquery-ui-1.8.17.custom.min.js
/components/com_jce/editor/libraries/js/jquery/jquery-ui-1.8.20.custom.min.js
/components/com_jce/editor/libraries/js/jquery/jquery-ui-layout.js
/plugins/system/jqueryeasy/jquerynoconflict.js
13 years 2 months ago #628 by admin
Replied by admin on topic Re: Advice?
well, you certainly have a mix bag of everything!!!
It is rather difficult to advise you without seeing the website live (and therefore cannot really know what is inside some library files), but here is what I think:
- select jQuery 1.7 and jQuery UI 1.8 in jQuery Easy.
- make sure the community component will work with jQuery 1.7 as it is set up to work with jQuery 1.3.2. Check that article for help:
article
- in the advanced options section of jQuery Easy, go to the 'strip remaining scripts' field and add
- I don't know what joms is, if it is a jQuery library, also remove
That should already clear things up a little. For further investigations, please post the URL. Thanks!
13 years 2 months ago #629 by geoffr
Replied by geoffr on topic Re: Advice?
Thanks Olivier! We have JomSocial and a few other components including the YooTheme template. I appreciate the speedy reply, I'll try to look at it closely tomorrow.
Kind regards,
Geoff
13 years 2 months ago #630 by admin
You are welcome Geoff.
