file jquery works but have a problem
13 years 2 months ago #519 by beaster9999
jquery works but have a problem was created by beaster9999
I have a live shop
www.cryshop.co.uk in the online shop you can view the product and if you move your mouse over it changes to a magnified view now I want to use and RMA system on the site. I can but must use Jquery Easy to get it all to work. but if I do this the magnify function doesn't work.
problem I can disable the jquery-easy plugin for the page and everything works but I have over 2000 products in my store that changes over time. and I don't want to put 2000+ lines of code in the disable plugin page.
can you help me please. if you need access please tell me thanks
Bri
13 years 2 months ago #520 by admin
Replied by admin on topic Re: jquery works but have a problem
I am putting the jQuery Easy 1.2.0 beta online today or tomorrow. It will address your issue (as far as I understand) by allowing you to disable a set of pages having a common URL (for allowing dynamic pages like yours).
For instance, you will be able to add '/tada/todo/tudu' and it will disable pages like '/tada/todo/tudu?id=123'
13 years 2 months ago #521 by beaster9999
Replied by beaster9999 on topic Re: jquery works but have a problem
That would do everything I want .. you are THE man thanks..
13 years 2 months ago #522 by admin
The jQuery Easy beta is out. Let me know if you still have issues with it.
13 years 2 months ago #529 by beaster9999
looks like everything is ok...Just wanted you to know..
Bri :cheer:
13 years 2 months ago #530 by admin
Great, thanks for the feedback!
