exclamation-circle Installation on Joomla 2.5.4
13 years 3 months ago #510 by Jerome2606
Installation on Joomla 2.5.4 was created by Jerome2606
I try to install this plugin via extension installation but it's seems that xml of installation is missing.
I can't install the plugin.
Is there a new version available for Joomla 2.5.4?
Maybe I miss something in installation?
Thanks for your help,
Jérôme
13 years 3 months ago #513 by admin
Replied by admin on topic Re: Installation on Joomla 2.5.4
Hi Jérôme,
there are 2 versions (one for Joomla! 1.5 and one for Joomla! 1.6+). Make sure you downloaded the right version. Ususally the plugin won't install when using the 1.5 compatible version on Joomla! 1.6 (or over) and vice versa. The Joomla! 1.5 version is about 20K of size, the version for Joomla! 1.6 or over is about 180K.
Let me know if you are still having trouble installing it!
