question-circle Upgrade to Jquery 1.9
9 years 5 months ago #4495 by Funesto
Upgrade to Jquery 1.9 was created by Funesto
Hello!!!
First of all, sorry if I sent a ticket, I misunderstood my subsctiption! Now my question:
I just purchased Jquery Easy licens e ..
Another developer (raxo) told me that I need Jquery 1.9 in my website ...
So I selected "Joomla 1.9" in basic JqueryEasy plugin configuration but theyr extension in not working anyway. Before I ask them again ... How can I be sure that I am loading Jquery 1.9?
9 years 5 months ago #4496 by syw
Replied by syw on topic Upgrade to Jquery 1.9
No problem, you can send an email or write in the forum, whatever suits you best.
Make sure you have added the sub-version number for the jQuery version you need.
You cannot just select 1.9 in the jQuery Easy plugin, you also need to specify the subversion (for instance, the 0 in 1.9.0).
To check if you have done it right, go to the source code of your page, look for the jQuery library among the javascript links (usually jquery.min.js), click on it.
If you see an error, you probably forgot the subversion number or provided a wrong one, otherwise the file will start with the jQuery version number.
9 years 5 months ago #4497 by Funesto
Replied by Funesto on topic Upgrade to Jquery 1.9
Thank you Oliver!
It worked fine! :-)
9 years 5 months ago #4498 by syw
Wonderful :-)
